slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
The problem with the Hobbywing heat sink is it is 2.3mm larger than the motor can so the amount of contact between the heat sink and the motor is not enough to help that much. Someone needs to make a heat sink like the Hobbywing but slightly smaller, or a copper sleeve to go between the motor and heat sink. I could easily make a liquid cooler for the motor, but a liquid cooler is a tad overkill over a toy car.
