Yes, definitely! See the vid that Tex posted earlier in your thread.Thanks man
Thanks man
Do I need to threadlock the screw inside the drive shafts? I’ve heard of wheels falling off
Thanks man
Yes. The screw that holds the composite driveshaft to the wheel axle (stub axle) comes loose. Add some blue loctite. That screw is in the driveshaft. Access it through the driveshaft.Do I need to threadlock the screw inside the drive shafts? I’ve heard of wheels falling off
I can tell you that this was the first problem that happened to both my senton and my gf's typhon which are both less than 2 years old. Do what you feel is necessary. Either way it's totally fixable with no costs involved except locktite.Thanks man
Thanks man
That is true. I have to use my Turnigy drivers for that.Fun Fact, the MIP 2mm driver is too short to reach that screw.
No way! Blue handle? Those are nice! Have a set myselfThat is true. I have to use my Turnigy drivers for that.
Yep. I don't use them much as I find the handles are too slippery. No grip. They do come in handy sometimes though.No way! Blue handle? Those are nice! Have a set myself![]()
They keep me from stripping screws in plastic. Human clutchYep. I don't use them much as I find the handles are too slippery. No grip. They do come in handy sometimes though.
Already done the ones in the wheels with blue threadlocker. First run yesterday its not as stable as my Rustler 4x4 vxl it sorta spins out alot I think this is because of the narrower tyre tread or could be ballooning. So far I like it, its fairly quick about right for 3s.I can tell you that this was the first problem that happened to both my senton and my gf's typhon which are both less than 2 years old. Do what you feel is necessary. Either way it's totally fixable with no costs involved except locktite.
The stock tires absolutely suck once you start getting up to speed.Already done the ones in the wheels with blue threadlocker. First run yesterday its not as stable as my Rustler 4x4 vxl it sorta spins out alot I think this is because of the narrower tyre tread or could be ballooning. So far I like it, its fairly quick about right for 3s.
The stock Ragnarok tires are fine for bashing but does not perform when you start going fast especially on road. They balloon easy and makes it harder to drive. Many have opted for the Granite wheels..Dboot Fortress MT as an upgrade. 14mm hex on the BRCC limits tire choice. An option to consider is 14mm to 17mm conversion..better selection of tires.Already done the ones in the wheels with blue threadlocker. First run yesterday its not as stable as my Rustler 4x4 vxl it sorta spins out alot I think this is because of the narrower tyre tread or could be ballooning. So far I like it, its fairly quick about right for 3s.
get rid of it and get a proper rc 6s kraton or 8s kratonApart from charging battery.
I’m a Traxxas guy well I was. This is my first Arrma.
The stock tires absolutely suck once you start getting up to speed.ye
Its good enough for my travel bag. I don't want anything that wont fit, for where I run it its perfect
Its good enough for my travel bag. I don't want anything that wont fit, for where I run it its perfectget rid of it and get a proper rc 6s kraton or 8s kraton![]()
Welcome aboard to the forum, great gents and info here. After a few runs, i updated my shocks and servos on all 3 of my Arrma vehicles. I really love my Big Rock. Have fun. Mosdef. your 1st but not your last, its an addiction.this Would be be so kind and attach a link for the red arms and carriers you are using on your big rock (in the photo) looks amazing and I’d like to get some
This might sound random or what ever but could you attach a link or provide some info for the red arms and carriers you are using on your big rock (in the photo) looks amazing, and I’d like to get some.Welcome aboard to the forum, great gents and info here. After a few runs, i updated my shocks and servos on all 3 of my Arrma vehicles. I really love my Big Rock. Have fun. Mosdef. your 1st but not your last, its an addiction.
