RC-Dude
I have a Carbon Z Piper (2,1 meter wingspan) and the magnets of the brushless motor came loose. Then I broke some magnets trying to see if I could fix it. Anyway I ordered a new motor and I have to print some spacer block for the propeller to fit nicely before the engine cowl. Now the positioning of the original holes to attach the motor is 36mm. The new motor has a 40mm hole spacing. So I need a set of 4 screws to attach the spacer to the aeroplane and a set of 4 screws to attach the new motor to the spacer. So first I have to attach the spacer to the motor with nuts and screws. I'd like to do that with a self cutting M3 insert so I can skip the nuts. Otherwise I have to remove the spacer first from the aeroplane (plastic attachment with a limited life of screwing screws in and out) when I have to reach the ESC.
Has anyone got some experience with this? Do I have to design the thread into the holes for the M3 inserts (other diameter M5) or just print it with 4,2mm and let the self cutting screw do the job. (M4 would also do and M6,5 external thread). I think TPU with lots of infill should be good. Or greentec PLA as it's more heat resistant in summer but it might split or create tension with the self cutting inserts.
Here rough pre-print but I would have to attach the motor to the spacer and have the nuts on the front side. So thread inserts seem appealling so I never have to detach the spacer from the aeroplane again. Used modifiers to strengthen the area around the holes with more infill and separate perimeters.
Forgot the center hole so I had to drill it.
This is how inserts look like. Here another example.
