3D Printing PLA Fail
ArrmaK8
Hello!
Ive tried printing mudguards, but this happens every time I try. Can someone please tell me what the problem is?
Ill now level the bed. Thank you.
It said that it was too low and i should raise it
There shouldnt be gaps between the infil lines. If there is its too far away.
I can also be because your plate is oil in that area. What printer you using?
Seems like you fixed the issue(s) by yourself. 👍
Next time something happens, we need a bit more information to better help you.
Like-
Nozzle temperature
Bed temperature
Print speed
Filament type
Z-Offset
Feed rate
More info the better.
Plus a few more photos..
Any how, no worries.
We All experience weird/failed prints 🤕
It's just part of the fun....
https://www.arrmaforum.com/threads/failed-3d-prints-lets-see-what-youve-got.61265/
Hello!
Definitely looked to close on the first layer.. glad you got it sorted.. 👍
It's actually not gaps.. look closer, it's pressure oozed filament around the sides of the nozzle giving the illusion of a layer line as it rises up from the surface..
