- Tennessee
- Felony
- Infraction
- Limitless
- Kraton EXB
- Mojave
- Outcast EXB
- Senton 6s
- Vendetta
Congrats sir. That benchy looks legit man!!
I'm starting to think I got a 3D printer to print parts for my 3D printer...
Printing now is a P1S riser and AMS stand - https://www.printables.com/model/784520-fixed-v2-vented-remix-updated-bambu-lab-ultimate-p
I am sooo over my head. I have no idea what's going on, but now I've downloaded and installed OrcaSlicer because why not throw more stuff at my small brain.
I really don't understand why picking "Bambu PLA" shows a MUCH faster print time (6 hours) then say my own custom filament preset or even the "Generic PLA" preset (8 hours).
What black magic does the Bambu PLA have the others don't?
I'm 99% sure I found the answer to this and that's "maximum volumetric speed". I'll look into it more in the morning.I really don't understand why picking "Bambu PLA" shows a MUCH faster print time (6 hours) then say my own custom filament preset or even the "Generic PLA" preset (8 hours).
What do you think of all the “high speed” filaments being released? It seems gimmicky to me since the printer itself determines most of the speed capability, but maybe I’m missing something.Yes sir.. you got it.. you can run flow calibrations to obtain the amount of volumetric flow the filament has.. Bambu PLA knows it will flow in the 30's.. typically generic PLA profiles that I've seen will show around 18-23..
This translates into limiting or raising the speed the printer can produce..
Which can also play games with you... For instance, a filament flows at say 30 at .2 layer height... If you cut that layer height in half (.1) you can now go faster as the flow demand is now cut in half.. it's a balancing act that you will get the hang of..
So I learned something today. When you click on "Splice Plate" the page that shows up next actually tells you some useful information, other than just showing how the model will be built line by line.
Did I say I have zero experience in this at all?
So comparing the volumetric speed limitation for the filament types, there IS indeed a big difference.
Bambu PLA Basic profile:
And the filament profile I created after doing a calibration created this:
I then tweaked the VSL from 12 to 20 and it certainly prints after but for this particular job I did, the print completed about an hour or so sooner but also looked like there was a lot of spider web material strung all over it.
I've since changed the VSL setting for my filament profile from 20 down to 18, but have also changed the max feed speed threshold from 8s to 5s.
I'm now printing the other pieces for my AMS stand/riser and have actually looked at some of the information after slicing the plate. Most noteably the Flow which appears to look very consistent to me.
Now granted all yellow could be bad for all I know, but at least it's all bad and not just parts of it. haha.
Even at the incredibly slow pace I'm picking very small things up so far, it makes me realize how much this machine really does for me. I've pretty much just treated this like a Circuit machine, where I just pick a file and print it and somehow everything tends to work out in the end. It's pretty neat stuff.
Holy moly. You are seeing the VSL to 60!? What printer are you using?I crank mine to 60mm/s and use speed settings to find my speed.. I don't let the slicer determine what I want to print at..
K1 max... k1 hot ends flow at about 32 mm/sec max with the correct filament..Holy moly. You are seeing the VSL to 60!? What printer are you using?
That looks great!Finished printing and putting together the AMS Stand / Riser. Didn't turn out to bad.
The P1S came with a 0.4mm stainless steel hotend that I replaced with a 0.6mm hardened steel hotend. I haven't noticed any major speed improvements and some items seem to need tweaking to get just right. So I've swapped out the 0.6mm with a 0.4mm hardened steel hotend.
Seems more prints, that I'm finding, are more designed with a 0.4mm anyways so maybe fitment might be a bit better. Plus I like the smoother look of the 0.4 vs the 0.6mm.
Getting ready to start printing the Smoothy Y-Connector as the hardware for it was just delivered today!
Moving to a bigger nozzle should definitely provide speed improvements, assuming the settings are similar. I wonder if you’re hitting the maximum extruder volume setting?I haven't noticed any major speed improvements and some items seem to need tweaking to get just right.
