I run XT150. I guess I didn't notice any heat or performance issues with the XT90 plugs and haven't with the 150s either. The main reason I switched to them was for my 8s Baja. I set mine up so that I can plug the batteries in series without adapters or loop connectors.Anybody move up to xt150 plugs. ?Notice any difference in performance or less heat.? Or run in a parallel with less connection?
Exactly,do you notice any performance benefit with less adapter or extra loop connector. Less resistance.easier on esc?
I've never really done any comparision but I don't really notice any performance benefit. I'm sure on a small scale there is a difference but not enough that your normal basher will notice it.Exactly,do you notice any performance benefit with less adapter or extra loop connector. Less resistance.easier on esc?
