Which iron do I need?
Warby
"Hurry up and wait"
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
Australia, WA.
  1. ADX-10
  2. BigRock 4x4
  3. Limitless
  4. Kraton 6s
  5. Senton 3s
  6. Senton Mega
  7. Typhon 3s
  8. Typhon 6s
  9. Infraction 4x4
So to date I've been using a small butane or an old Weller 240v 40w soldering iron and they have done the job for up to XT90 connectors.
Now I've venturing into 8s systems with QS8's, 8mm bullet connectors and 8 gauge wires.
What wattage iron will I needs? Would 60w be enough? They will be 240v.
This is what my local hardware store has.
I use a 60w on everything right up to 8g wire, for bullets ideally you want a small blowtorch type heat device 👍🏼
This video of Brandon's, shows the method of fitting bullets the easy way..!!
Thanks for the vid
Been using Duratrax TrakPower TK-950 Soldering Station for quite some time now and have no complaints. Many times the smaller irons don't get hot enough or take too long to get to temp. You can find them on ebay for cheap every once and a while.
So that's another 60w vote. 👍
I use a Weller 80w for 6 to 7awg wire with big connectors. That 60w should work fine too though. I would still lean towards the 80w personally though.
The 80w is only $5 more than the 60w Weller so I might as well get it, if it's in stock.
I’m gonna say buy a digital soldering station for sure. I have a super inexpensive one that just works a treat. 900° for QS8’s or bullets makes the job perfect in seconds. And it regains heat very quickly. I feel you will struggle with a 60 watt iron, it’s right on the border of being able to get the job done. It sounds counterintuitive but if you solder a QS8 at 850-900° it puts much less heat into the connector itself and prevents the cables from conducting dangerous temps back into the ESC or battery. That’s because you’re making the connection very, very quickly rather than keeping a lower temperature iron on it for far longer to get the job done.
A decent station and this specific solder will make you look like a hero and save a lot of frustration. The items below will have you looking like a pro with a little practice.
https://www.amazon.com/gp/product/B07RVMZNYR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
https://www.amazon.com/gp/product/B004X4KS7O/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01MR49JY1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B008ZIV85A/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Thanks for the info 👍
Hard to beat the 3090's price point with everything it comes with.. js😎
Only available in 110/120v unfortunately.
All I can say is that the Temp. recovery ability of a specific Iron matters. If the Tip cools down too much and fast, when applying heat to the joint, this ruins a wet dream. Some Irons let you know the Tip needs to recover its set Temp. Because it cooled down, the joint being a Heatsink of sorts. A quality soldering station can sustain its set Temp precisely. And shows it on the display. What separates the men from the boys. I always solder with 750+ F setting at a minimum for large gauge connectors and wiring.
And always use a Large Blunt Tip for the large gauge stuff.(y) Not doing this is simply the wrong way. I see many Noobs do this. Using pencil tips.(n)
:cool:
:cool:
Thanks for the tip about the tips. So get a chisel tip.
