Typhon Where can I find high tension Typhon rear springs
Very firm
If your road is smooth enough turnbuckles,,,.stiff springs will cause ya problems.strip threads in a-arms,screw falls off chassis tab ya crash...screws put alot of tension on chassis from spring tension
Good to know thanks for the heads up . I just wanted a little stiffer then factory .
I don't know how it is on the Typhon, but on the Infraction it comes stock with medium stiffness springs (front/rear 27 & 26.8lbs/in. respectively). Arrma makes 38lb./in. springs for it.
How stiff are we talking? I used Kraton springs on the rear of my typhon and it worked wonders for me. They're stiffer but not super stiff.
😂 I run talion fronts in the front
You definitely gonna have some work to fit 8s under the typhon body. :eek:
Yea will need to run race packs. Shorter run times but should be fun.
I highly doubt I'll be running 8s all the time.
4s-6s is a lot already.:LOL:
beautiful! You can totally replace the rear body mounts and posts to raise the rear of the body. IIRC thats what I did to fit 8s but it still a tight fit and made my body a little uneven with the 8s batteries but still worked great. :cool: (y)
Good info to know. I shoot from the hip for the most part with RC's so it's good to get some insight once in a while
Thank you!:)
here's a couple 8s speedrun typhons I did.was able to fit 2×36mm tall packs under typhon body after raising it..BTW the 3s body is about 1in taller,more room for packs... @Jeppyjep remember that if ya plan on going 120+++ that the second rear squats lower than front car gos airborne.that 4080 will be making the rear squat under power...cause blwovers are the worst way to crash up a car,cartwheels an barrel rolls will do some damage quik...had 5 runs on this new body👇,I was sooo pist
Thread '130mph+++ stretched typhon SPEEDRUN build' https://www.arrmaforum.com/threads/130mph-stretched-typhon-speedrun-build.38711/
After a few blowovers I quit useing springs.i now only use solid links instead
