- Rhode Island
- 4x4-Mega
- Kraton 6s
- Outcast 6s
- Outcast 8s
- Typhon 6s
Anyone have a link for high tension rear typhon springs ?
Check lengths,on road springs only,,no good off road,super stiff springs
Ya doing a on road typhon similar to these?
I don't know how it is on the Typhon, but on the Infraction it comes stock with medium stiffness springs (front/rear 27 & 26.8lbs/in. respectively). Arrma makes 38lb./in. springs for it.Good to know thanks for the heads up . I just wanted a little stiffer then factory .
I run the Kraton exb springs on the back of my Typhon. Teknos in front.My friend Typhon 6s runs with Talion Exb springs, they are more stiffer than stock
How stiff are we talking? I used Kraton springs on the rear of my typhon and it worked wonders for me. They're stiffer but not super stiff.
Yea will need to run race packs. Shorter run times but should be fun.You definitely gonna have some work to fit 8s under the typhon body.
beautiful! You can totally replace the rear body mounts and posts to raise the rear of the body. IIRC thats what I did to fit 8s but it still a tight fit and made my body a little uneven with the 8s batteries but still worked great.Yea will need to run race packs. Shorter run times but should be fun.
I highly doubt I'll be running 8s all the time.
4s-6s is a lot already.
Good info to know. I shoot from the hip for the most part with RC's so it's good to get some insight once in a whilebeautiful! You can totally replace the rear body mounts and posts to raise the rear of the body. IIRC thats what I did to fit 8s but it still a tight fit and made my body a little uneven with the 8s batteries but still worked great.
