Hi
Please can somebody let me know what the purpose of this little grub screw is on the diff housing case? Thank you
Sun gear just easily pulls up off of shaftThanks for replies…
But how can you pull the pin out as the sun gear sits on top of it… making it impossible?
If the pin must slide out of the Input gear's shaft, obviously the Sun gear comes off of it First. Get used to diffs, because they need regular maintenance and service. All RC's do. I suggest you watch some YT vdeos. It will help you understand diffs way better. Then, by doing it yourself, muscle memory will take over. Will be easy. The parts and all. Need to start somewhere. Just Need to watch someone else do it first. The best way. Watch several.Thanks for replies…
