What are you using for grease in your diffs?
Coconuts
  2. Kraton EXB
  3. Mojave
  4. Outcast 6s
Hey all.
I have a question about what you use for greasing the differentials in your Arrmas.
I talking about the grease that goes on the main spiral and main input gears in the diff cover.
The grease that comes from the factory is super thick and looks decent.
I've used marine grease and udder butter in the past but I'm out off both. So I thought now would be a good time to ask around.
Thanks.
Jake
What nobody uses the blue Lucas marine butter!? I use the grease gun and load up!
Does marine grease work on cars?
Sure does!! Especially since I take a garden hose to my rigs after a muddy bash. It’s not as thick as the red and tacky but it coats all rotating parts and stays!
Maxima Waterproof Grease and Green Grease have been in my arsonal for many years now after my o-ring lube (Green Slime) was gone. I'm still unsure which one I like better, but both have been used for o-ring lube, diff pinion/ring gear lube, and repacking of bearings.
