Limitless TP 4070CM SOLDERING GON WRONG HELP!!
Samu.s
Hi I have recently soldered the bullets on my tp motor. But some of the tin has spread to my plugs as you can see in the pictures below. Is this very bad or should i not worry ?
Try using some light sand paper .sand it down a little until it fits .tin is conductive so it's not going to hurt .you could use a Dremel with a sanding disk.or just start over and get a new bullet
Did you try to to melt it off with the heat iron? Don't see why it wouldn't
you could heat it up with a little butane torch and wick it off
