- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
Get the castle link and check out the settings and pull data logs.I built a limitless Xlx2 TP 4070 now every time I go to punch it it’s like the power gets shut off if I get on it smooth there is no problem she goes can’t figure it out the voltage cutoff is turned off if anyone knows please need help
The logs tell you exactly what is going on, but what you are describing is the low voltage cut-off behavior.
