Notorious Tire rod end upgrade?
Lil Dylan
Houston, TX
  2. Notorious
My notorious keeps popping off the inner front tire rod end. Obviously I can replace with new end for cheap but is there a good upgrade for this? Thanks.
It's got a ball on the other side and that might be worn as well. So it might not be the rod end or it could be both.
I had some extra rod ends sitting around and wound up using that. Doesn't seem like upgrades are really available in that area.
Those are designed weak points/wear item failure modes, I'll replace rod ends on terrible landings for eternity instead of upper front and especially any lower A-arms.
Agree with above. Path of least resistance and all that. My poor driving led to me consistently breaking these on the same rig. Obviously ally is out of the question so I jerry rigged a pair of rears to fit up front. Beefed it up a little and stopped me breaking them for a while.
