Dan B.
Area man
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- Southern Vermont
- Fireteam
- Granite
- Limitless
- Mojave EXB
- Notorious
- Outcast 6s
- Typhon 6s
Well, here we go…. This one might take awhile, so if you follow the build I appreciate your patience. I contacted David from Scorched at the end of September with a detailed wish list for a SWB speed chassis that incorporated the rear Lim diffuser. Instead of incorporating the front Lim splitter assembly it was done in the “Full Length” chassis configuration like the FL “Special” Lim chassis he did a few months ago. Totally flat from front to rear. So here is a SWB chassis that can take full advantage of proper aero for the first time. I am so psyched for this build!
Also of note, if you noticed it’s 328mm instead of the Arrma SWB 325mm it’s because the motor mount is positioned so the spool is centered in the chassis and not offset in order to reduce the high misalignment center shaft orientation of the short chassis Arrmas.
