- UK..
- Infraction
- Mojave EXB
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 6s
So as the title says...?
What sort of suspension settings are working best for speed running..?? ( Infraction/Limitless )
I've been looking around all the Youtuber's and they all seem to run really low spring collars, ie: really stiff setup.
Raz doesn't even seem to have rear springs on some of his cars..!! but maybe I just can't see properly..?
I know you need the car to have a rake to it, ie: front lower than the back.
And I assume the lower arms are horizontal to the ground, other than that what else is there to set..??
Maybe fitting some sort of rubber bump stop onto the shock shaft so the car doesn't bottom out..??
Ride height is going to depend on your road surface I would think, I do understand that ideally you don't want any air getting under the car so a low ride height is needed..
But what's an ideal height..?? and how do you measure it..??
I've been tinkering with mine and when you stiffen up the spring collar the car rises, so your going to need to use your droop screws to adjust the ride height..?
Any tips, just add them below..??
