Suspension setting
ASenton
Australia
Hi just doing some speed runs up and down the street. Still has the standard springs haven't got any stiffer ones yet. Just want to know is it better to have some rear rake or to keep the rear more level. And the droop is still standard so not sure to leave it there or try adjusting for less droop but then do i do same front and rear equal thanks.
Yes run rake, I use nero springs on rear. Stock front springs. With cut shock tower.
I adjusted spring preload ran less droop with bit of rake handling much better
