When you do this, you’re no longer able to run the center braces and can only run the tower to tower correct?I have done it to my TLR chassis and both Mojave chassis
Also, if I’m running the stock center diff I’m going to have to raise it to accommodate the stock length driveshafts. As well as find an alternative to mounting the battery tray.I have done it to my TLR chassis and both Mojave chassis
You can definitely get them straight but not levelYou will never get the driveline shafts perfectly straight and level.
For the typhon I’m made center brace’s I’m running custom drive shaft that I make
How and what pinion spur gear are you running 34-34 will not workUhm..
Excuse me sir.
Actually you can get them Both Straight AND Level.
Take a peek at the infraction/Felony/Limitless
Not the clearest photos with all the other components in the way .
But you can see the center driveshafts are as level as the battery tray..
How did you get your center diff that low
Very interesting. Looks like the v1 center diff mount? I’m trying to maintain the actual center diff, I have the RRP 40T which meshes real nice compared to the stock arrma spurs. I like your custom bracing looks good.For the typhon I’m made center brace’s I’m running custom drive shaft that I make
The typhon chassis is very different from the infraction that’s what we where talking about TEXHow and what pinion spur gear are you running 34-34 will not work
But what are you doing for bracingAll done much straighter. Sounds better when running around on 4s as well. Will test 5 and 6s tomorrow.
I have to man handle the battery when it’s strapped in to get it even close to touching the spur gear.
I have the tower to tower brace. Which works fine. Just need to clean up the little bit of slop in the pivot balls on the ends.But what are you doing for bracing
Keep an eye on your stock center drive cups I had one come apart I’m running a spool now
