Aaron5
Okay so i just took my talion out for the 4th run. I noticed it didnt turn as well as before. On my third run i wound all the shock collars down for maximum ride height and it turned fine. Now it will turn both ways fully until its on the ground it doesn't have enough power to turn fully. If you go in reverse it turns fully but thats it. Is this a servo issue or a weak batt?
Edit: I looked closer at the servo and noticed that the servo horn(black piece that connects to the saver) has damaged the top of the saver a little bit. Could that have damaged the servo gears? I can turn the wheels left and right easily so theres no binding. But when driving they barely turn. If you stop it will turn slowly but stops in the middle when turning back the opposite direction and when turning after that sitting there it barely moves from straight.
