Racer X
I bought a new Infraction.
I drove it up and down the street with some small 1500 ma 3s batteries from a crawler. It was fine. I finally got the two 5000 ma 3 s smart batteries. I also picked up a Savoc servo to replace the original RTR servo.
I made a quick test pass and everything was fine. Made a second pass full throttle and then used full brakes. As it went past under braking it started to beep and stopped. Nothing… no steering no throttle red blinking in the ESC.
First I tested the servo . I was dead. It would not work in another car. I swapped the servo for a Reefs 444 and that worked. But I am still getting the red ESC light. I tried calibrating and rebinding still nothing.
I swapped in an SR515 receiver and it works.
Note don’t drive full throttle without a gyro. It got up to speed and then spun like a top.
Added a gyro and now it is perfectly normal except I have a low voltage warning popping up on the transmitter.
I am going to get another Sr6110 AT receiver but why did the receiver and servo stop working?
