Lil Dylan
Hello all, I have a Kraton 6s
Castle 1650kv---MMX8s, 20-tooth pinion, DX3 with non-avc receiver, Oovonic 100c 6000mah battery, timing 15 degrees, punch 25%. Sometimes when I'm doing a little speed run the car will stutter at WOT. Almost like a rev-limiter and it happens the whole session. This has only happened maybe 2-3 times out of 50 or so runs on this setup. Any ideas on what this could possible be? I thought it might be ripple voltage but the log doesn't show that. Max amperage is 175amp. Also, this happens when the car is fresh so it's not a temperature issue. Thanks
