Nemo
Hello,
Looking to make a Limitless V2 run like stock infraction v2 with the stock trx that has AVC and make it run like a dream, meaning that you can accelerate without losing control and you can drift so easy without losing control. The thing is that stock infraction v2 uses Spektrum 3Channel DX3 2.4GHz DSMR radio and SR6110AT Receiver with AVC (Active Vehicle Control). When I search for this trx it comes as SPM2340 which is DX3 Smart 3 channel transmitter with SR315 receiver and not the SPMSR6110AT Receiver. I can find SPMSR6110AT Receiver separately. Also I find SPMSR6100AT as a bargain, but does it behave like SPMSR6110AT or is it inferior? Also I find SPMR2345 DX3 SMART DSMR ProMoto TX Only, is this superior to DX3 2.4GHz DSMR radio? Looking to get the functions I mentioned in the beginning in a vfm deal. Could use your advice.
(Esc n motor on Limitless V2 will be way stronger than the stock esc n motor of infraction v2)
