Lurkios
Picked up a Kraton a few days ago on the excellent reviews. First run I got about half a battery in, grass and pavement - don't think I ever got it past 75% throttle (thing was a beast), one flip from too tight a turn in the grass. Only problem I noticed was backing up - front wheels would not hold straight at all above minimal speed. (Possibly normal?)
Few days of rain and back out - still babying it since it's new, some speed runs back and forth on concrete, climbed a moderate hill... save the backing up issue, all's well. Figure about 30 minutes in it rolls past me and I notice the sound's changed drastically, kind of a grinding, though it didn't seem to be acting much differently. Seems I'd broken a tooth off the pinion attached to the motor. Popped the pinion off, gave it a push and the grinding was still there - coming from the center differential. Mind you, no crashes - a few wheelie's was about the worst of it really (wheelie bar installed).
So - two questions:
So - two questions:
- Any idea what I'm in store for when I get this diff apart? Normal-ish behavior (a bit jerky), but a terrible grinding sound. Spur gear seems in-tact.
- How easy is it to deal with Arrma support?
