- Notorious
- Talion
- Typhon 6s
I converted my Fireteam to a Talion XL with Talion towers and shock shafts, but using Fireteam springs. I initially decreased the spring preload almost fully and set the droop at level in the front and slightly higher in the rear.
I really like this setup for high speed dirt bashing at my one good spot for that. Went to anothe spot with the small ramp I have just to do some simple smaller jumps and it really bottomed out pretty bad if I tried to hit it at anything more than half throttle.
What would be the easiest change to avoid bottoming out? Id like to hit the ramp with it and have an easy swap back to current setup.
My thoughts so far are:
- Move rear shock position on control arm in closer
- get Backflip MTs (Im running LPs)
- change spring preload in rear
- build a better ramp setup
Would one of those work or something else I'm missing?
