Best Shock-Bump Stops-For 6s Rigs
djrahbee
Send-Flip-Break-Fix-Repeat 🤙🏼
ArrmaForum Fan
VA
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Kraton EXB
  5. Mojave
  6. Outcast 4s
  7. Outcast 8s
  8. Outcast EXB
  9. Infraction 4x4
Sup. I keep pooping out front cvd's. Happens when I'm hitting the ramp. Did it with rpm arms now it's happening with stock arms. I have taken shims out. I have M2C hex extenders on my Kraton, could this be causing issues? Looking for some bump stops that work better than fuel line. Seen it discussed a few times on the forum but don't think I've seen or can remember what people are using. Bump stops or any other solution..✌🏼
https://jconcepts.net/rubber-bump-stops
Axial On HH
Another Axial on HH
AMain
More from HH
Thinking about getting these..
Got the wheels turnin now. Got this rubber gasket from ammo cans I keep finding uses for. Used under motor cans to help keep from flexing on landings. Now, I think I might be able to cut small pieces of it, poke holes and stick a couple on my shocks. Worst case it doesn’t work.
Well I think I have a pretty good temporary permanent fix. The rubber gasket worked. Man I don’t know what I would have done without all the feedback from myself. 😂
I figured I should mention those sexy lime green shock collars are from none other than @Tex Koder himself.
#3 and #4 are the same part. I haven't had a chance to test them yet as the weather has been very uncooperative. I have some of the Axial 1356 iirc never thought of trying them.
Was this a factory spec rig, did you change any tower/chassis/shock combination?
Moving the upper shock mount down is essentially what you’re doing by limiting full compression travel and what I do on my custom Mojave builds to get full droop/articulation instead. You can also swap to dogbones to help allow floatation instead of being point fixed.
Not stock, it has CF towers, Viatavon bulkheads, M2C hex extenders...5mm I think. Moving the shocks might help. Haven't tried that yet. I've been away today enjoying the last snowboard trip of the year. Thanks guy! 🤙🏼
Well fellas..I am happy to report that I got a full pack in today with ZERO cvd poppage! I believe my solution worked like a charm. I'm not even going to bother wasting any money or time ordering anything. Took a few tumbles that surely would have popped out before. Love putting my rigs back on the shelf unbroken. 🤙🏼😎😁
