G-Man
Well after a few runs I have noticed the flex in the plastic steering servo mounts others have talked about. I have looked through other threads on servos etc. I have chosen to replace the stock servo with a Savox SW 1210SG. That servo seems to have the most torque for it's size in a waterproof case. Unless someone knows a better choice.
Now my real question is what mount to use for that servo? I would like to use GKA mounts but which one will work? There are two, one is listed as taller fit and the other is listed as standard fit. Now do these GKA mounts bolt right in? Also is there anything else asides from the mount and servo recommended? Like a better horn or whatever. Any pics of your steering servo setup will help greatly!! Thanks in advance!!
