You must have some super slowmo vision to be able to tell a noticeable difference between those two speeds.
Nah, but seeing .08 then seeing .15, it was noticeable.
uhhh huhhh, I guess it my old eyes.Nah, but seeing .08 then seeing .15, it was noticeable.
I have one of those cheapo ones that was like $14, it's horridly slow and feel slow when driving. I think it was .20, maybe a bit worse.uhhh huhhh, I guess it my old eyes.
Its terrible gettin old.
Very true! After I tested this I was able to swap out the npn transistors to a modified model with different doping. With the modified boron and phosphorous content percentage I was able to improve the free valence electron flow from the base to the output through the transistor. The switching function of the transistor improved reducing the response to nearly 1/2 the original specs.
My first batch of transistors on a 300mm silicon wafer cracked due to an impact on the edge, but still plenty of usable ones on there:
-Liberty
The eBay cheapos I have are like 0.18 so slow.I have one of those cheapo ones that was like $14, it's horridly slow and feel slow when driving. I think it was .20, maybe a bit worse.
It is pretty wild what those wafers value are!No way! I used to work in a silicon wafer fab too (Motorola) Actually worked in the Diffusion dept doping that schizzle...so I know exactly what you are talking about. Deffo a good way of solving the issue although I'd probably have just went for the blue servo case instead of rectifying the flux capacitance.
That broken wafer probably just cost the company between 10-15k though. Did the quartz jig warp or did the oven wafer transfer mechanism go out of spec?
I work in the bread department, in charge of loafingIt is pretty wild what those wafers value are!
Common robot handling issue on the back robot into the plasma chamber for this Mattson Aspen III machine.
I worked in Plasma Engineering at Texas Instruments
-Liberty
Reds always faster anyway
Pink all day longPink or brown?
Yep, the red is slower, mine was just delivered. In my hand, it seems to hold position far better. Not sure why I didn't try the blue one in hand to see how it felt outside the truck. I'll do that later. Without power, the red one is way harder to rotate than the blue one. Perhaps a lot lower gearing or stronger magnets in the motor. It reminds me of my JX Servo DC-5821LV, just a hair faster.The coreless ds servo 25kg blue is faster than the standard red one i had the 25kg and 25kg coreless and the coreless makes a huge differance and a lot smoother than the stock servo or the red servo
@LibertyMKiii & @Ari33, are you guys planning on building one of these? If you are, I want first dibs riding shotgun.
