- USA, Georgia
- Gorgon
- Infraction
- Kraton 6s
- Notorious
- Senton 3s
- Infraction 4x4
Is there anywhere that RED Loctite would be used on an RC? Any model. Any place that it's necessary or needed?
Motor mouth screw and pinion. I use it on everything pretty much almost. Just different amount of it for X application. I do not trust blue when it comes to important screws. Blue comes loose very easily by experienceIs there anywhere that RED Loctite would be used on an RC? Any model. Any place that it's necessary or needed?
Dude I’ll put torch heat in the pinion and braze solder in the hole, alright!.. then I’ll slap it truck okay!…then I’ll rip it with all that heat still in it, see!… my friends call me Jimmy hot pinions, I bleed red loctite.I find it so to hard to believe that people don't read and understand about all the grades of Thread locker out there.
Red anything is never to be used for our small M3, M4, Or even M5 screws. If you find a need to jump to Red, you are doing something wrong and Red is just a Crutch for you. And just because Chinesium Red or whatever that TL crap is "assumed" to be, and used during Factory assy. of some of our Arrma rigs, means nothing.
There are very few exceptions to this. Like when building a Higher end Kit built RC Model (usually Some Nitro rigs) And the manual specifically states to use Red TL on certain parts.
I was a Toyota Tech and a car gear head for all my years. Red and Blue TL have their specific applications. Trust me I have played with Red before on Small screws. NG
