- Granite Grom
- Infraction
- Kraton EXB
- Senton 3s
I while back i posted a solution to the flashing red light of death on the v5 version(works with many types of Esc’s) i found out why and what caused it to break the only problem is that the water proof seal on you esc near the motor wire is leaking and to make sure of it try my sparking trick or move your blue wire toward the center of the car and it should start to beep like normal and to fix this you can take an air can and dry it out then put some type of unharmful seal to stop it from happening again the reason it doesn’t work it because the blue wire it arking with the fan wire (plugged in or not) cause it to pull up the broken esc error code took many months and many burns from me being stupid of the same problem to find a proper solution (this problem also unbalances your batteries and kills cell) but now you can start to save some batteries hope arrma see‘s this and takes notes to fix this in the v6 series. Hope this helps you out.
Let me know if it doesn’t work so we can try to figure it out.
Be careful please.
Be careful please.
