That should fix the problem..... that Hot Racing part is a common solution for replacement servos on the 6s Arrmas.
Yep. And a adjustable link because the servo was so tall it messed with centering. I was able to correct it with that & get it dialed in just right.Another fix, my way of doing it, is get rid of the rubber gromets and direct mount that puppy. It is a beast and needs no shock protection
Or you can put a spacer "washer" and longer screw in the connection on the servo saver, this is totally fine as well.
Both of these are acceptable and free!!
In looing at @332_rc pictures that is exactly what he has done, he put spacers on the link connection to the server saver.
You also direct mount without rubber grommets , do to these newer servos being so beefy we almost don't even need servo savers anymore either. On almost all my trucks I run with an almost fully locked servo saver and direct mounted servos haha. They handle it just fine.Yep. And a adjustable link because the servo was so tall it messed with centering. I was able to correct it with that & get it dialed in just right.
Oh god... No don't do that... Ever!! Why am i not surprised you'd suggest this.You can also tap the arrma 23T offset horn on with a brass hammer in a literal “pinch”.
Blasphemy !!...... OK, maybe with a cheap servoYou can also tap the arrma 23T offset horn on with a brass hammer in a literal “pinch”.
Cuz you use cheap servos without hardened steel gears? Not sure, I’m actually a “real” engineer and understand material science. Software guys are like paleontologists/dentists of the doctor world.Oh god... No don't do that... Ever!! Why am i not surprised you'd suggest this.
I do enjoy schoolin you hahahha, these are the type of servos I use.... $200 each little boi - Titanium geared lolol, look em up!!Cuz you use cheap servos without hardened steel gears? Not sure, I’m actually an “real” engineer and understand material science.
I agree, nice looking servo saver.Also @332_rc - thats a sexy servo saver u got there. NICEE
It's a Basherqueen one. Appreciate it.I agree, nice looking servo saver.
