Powered screwdriver
The dewalt with gyro is awesome & you can switch from pistol grip to a long / straight grip
Is it true that there are 2 models of the Dewalt Gyro driver?
One does not have a pistol grip ability? Only straight? And the straight one has no clutch from what I understand.
Pistol grip with clutch is $120. (2 batteries) More value.
The plain straight one, without clutch is $90. (one Battery) Less value.
There are 2 versions yes - the one I have has a clutch and you can switch it from pistol grip to straight grip (the handle rotates accordingly & swivels)
I personally use both options & mix it up out of boredom
This is the one I got which includes charger, 2 batteries & a bag:
https://www.amazon.com/dp/B00DL7QDS2/ref=cm_sw_r_api_i_RBPZ53RK49EJ4C8GN7TB_0?th=1
You can see here that the handle swivels
