- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
Worlds fastest Traxxas is running a MMX8s on 6s power.
177 mph 4tec 2.0 running a SAGA custom RC carbon fiber chassis.
The car will be capable of it, just not sure if I have a road that is smooth enough for the tiny 65-69 mm tires these 1/10 cars have.For now..??
I hope your going to beat that speed with your 4tec..???
Technically not an official pass if you don't/cant drive it back to yourself so the FB GPS league wouldn't count it, but I think it's valid, since there was no crash.
No that would not count. It has to drive backThat's ridiculous. Does bookface count Phil's when he gets into his car to find his RC at the end of the street?
I broke a fan blade on my MMX8S today and also the power switch no longer works, it’s permanently on. This was in the EXB today. Going to have to spend some time on the phone with Castle tomorrow.
As Jon mentioned that would not count. It is the same group leader that runs ROSSA. I am glad they at least allow GPS. ROSSA requires a $1200+ TrackMate speed trap setup which is way over priced. You could make your own with a microcontroller setup but they require that brand specifically.That's ridiculous. Does bookface count Phil's when he gets into his car to find his RC at the end of the street?
No plan on getting their fan. I am worried about the power switch not working.So they can send you another broke butt fan? Don't even bother, order a nice fan.
Well that's a dumb rule and If I was in charge it would be squashed..
I have a bunch of fans to choose from and can solder the plug from the stock fan on any of them no problem. But, my throttle cut out like it was LVC at the time that I noticed the power switch won’t turn off. The pack was at 3.8v per cell. I have LVC set to 3.4v. It was a Graphene Panther 5.0 6S pack. Pretty sure something more serious is wrong with it.Probably a short inside the switch, no biggy. Install a new one, grab a WTF fan and go play.
The ideas of these rules is very similar to rules at the Bonneville salt flats and other land speed organizations. Because it is electric we cant easily do the whole average of 2 passes concept due to voltage dropping each run.
Yeah I have the max 5 and max 6 and the mmx8s is the strongest and has more features. I also have 2 xlx and i think its peppier than the xlx, and can run sensored so i like it a lot more plus the size you can put it places you can't put a xlx.The fact that it did 120mph on 6s with a 1515 castle 2200kv is an indicator that it outputs some high amperage. More so than the max 6 or max 5. Could be the goto ESC for all uses? Only time will tell.
Any ESC running 7,000 to 12,000 watts is a ticking time bomb in my humble opinion. Even the XLX is not immune to this.Yeah I have the max 5 and max 6 and the mmx8s is the strongest and has more features. I also have 2 xlx and i think its peppier than the xlx, and can run sensored so i like it a lot more plus the size you can put it places you can't put a xlx.
Only problem is im on 3rd one, as its getting expensive to use my favorite esc.
One caught on fire in my living room when I tried to do a kv test through castlelink.
The second one stopped working after a speed run in my limitless, on acceleration It felt like it hesitated then my car flipped and I grabbed it and went home later trying to grab the data log and use it i noticed it didn't work anymore no real signs of damage or smells.
Then i got a 3rd one and had the female bullet connect on the C plug melt off.
Im hesitant with contacting castle for warranty cause 3 of them? Yeah 3. I looked on there site and saw you have to fill out forms and provide receipts im going to have to see if i can pull up bank records or sites where I got them from, 1 was on ebay 1 on Amazon 1 from amain. Seems like such a headache. ☹
you have had 3 mmx8s go bad? wow insane bad luck brother. I bet i have had 10 or more. I build cars for people and usually use mmx8s. My favorite esc now. i have 3 here now. just made a run with the 1717/mmx8s combo in my slash at 153mph. love that combo now.Any ESC running 7,000 to 12,000 watts is a ticking time bomb in my humble opinion. Even the XLX is not immune to this.
I got mine on eBay also and pray nothing like this happens.
My buddy says it is always best to purchase direct from Castle if you plan to take advantage of the warranty. One day ill take his advice ?
I busted my new WTF fan in about 6 minutes. 2 blades gone.Probably a short inside the switch, no biggy. Install a new one, grab a WTF fan and go play.
