farshadmaleky
just wondering if anyone knows if the outcast exb center diff and spur is the same fit as the outcast v3 center dif and spur. is the exb one better quality and more durable. thanks
I believe the main difference is material and I'm positive they are both the same and interchangeable. The EXB would be aluminum where the regular one is composite plastic.just wondering if anyone knows if the outcast exb center diff and spur is the same fit as the outcast v3 center dif and spur. is the exb one better quality and more durable. thanks
thank you brotherI believe the main difference is material and I'm positive they are both the same and interchangeable. The EXB would be aluminum where the regular one is composite plastic.
