Anthony jaques
I'm building the arrma aluminum diff conversion and I have mugen shims.my question is the breakdown shows 2 arrma shims on outdrive satellite gear side I'm using the mugen but only have one set do I put one arrma under mugen seems wobbley. Do I get another shim set or do I just run 1 mugen which seems the most logical but there is the tiniest of play when pushing the drive cup back and forth. So I guess my real question is do I really need to shim's in that place or do the gears press together taking up that tiny maybe 1/4 Millimeter . I apologize in advance if this was not punctuated properly. I am just trying to task a question thank you for your time.
Hear is the breakdown to show where I'm talking about
2 shims sryI'm building the arrma aluminum diff conversion and I have mugen shims.my question is the breakdown shows 2 arrma shims on outdrive satellite gear side I'm using the mugen but only have one set do I put one arrma under mugen seems wobbley. Do I get another shim set or do I just run 1 mugen which seems the most logical but there is the tiniest of play when pushing the drive cup back and forth. So I guess my real question is do I really need to shim's in that place or do the gears press together taking up that tiny maybe 1/4 Millimeter . I apologize in advance if this was not punctuated properly. I am just trying to task a question thank you for your time.
