Motodeficient
Hey everyone!
I've got a Granite 3s that I am converting to 4s.
So far I have installed or procured:
-HW 3665SD 2400KV Sensored Motor
-HW Max10 ESC
-Kraton 4s differentials Front/Rear
-Steel input gears for Front/rear
-Arrma HD CVD's for Front/Rear
-Hot Racing diff yokes Front/Rear
-Steel Spur gear for slipper clutch
I have mocked up the Kraton 4s diff with the metal input gear and Hot Racing yokes in the front, see below picture. The diff has a little bit of side to side play in the hot racing yokes. The stock diff didn't have any side to side play in the stock composite yokes. I'm guessing this play needs to be addressed, but I'm not sure where to start. Do I need to do something inside the diff, or do I just need to get some shims to install on the outside of the diff behind the bearings? How do I know which way to shim it? How much play should there be between the differential gear and the input gear?
-HW Max10 ESC
