Im thinking about using washers or cut plastic for internal spacers (below plunger).
Will diy parts work or do i need fancy precision parts from arrma,
Also is getting the truck 1-4mm lower gonna be worth it.
Thanks! Have a good day!
Wow, you have answers my question. And provided me with a cheap alternative to retail.Nothing wrong with a bit of DIY-ing.
Should work just fine.
If you're wanting some more precision, I've already made limiters for 8S shocks..
https://www.arrmaforum.com/threads/...ollars-bump-stops-limiters.64894/#post-987170
I can scale them down to 3S..
Im going to try cutting. Thanks for the 110% answer!
