slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
On my Lc Racing vehicles I had to red loctite the diff pinions and diff cup grub screws on otherwise they would back out, the diff cups were just annoying but the diff pinions caused damage sure only $5 in damage but still tedious to replace the diffs gears.Blue gel I have also. Its expensive and you go through more in the end. LT 243 seems fine right now. 242 ok also, 243 works great on used hardware that's been loctited before and dirty or oily. Some say overkill and specs say 1/4" or larger, the 243 is strong enough for motor mounts and pinions and high load setscrews, and can also be used on lighter load areas. Best all around. I do use Red on my motor pinion grub and diff input cups. The setscrews get worn easily and need Red if you want to keep using the same one. I still do that. I can see what a loose motor set screw can do damage wise to expensive spurs gears. To each his own. As long as it is blue "something", you are good to go. I have a collection of diff. LT.
