helizrnew2me
are you guys putting loctite on your grub screws right out the box before running the kraton? just curious . had to do that with my cen colossus .
the grub screws for all the diff cups . pinion ,ect,ect............Which grub screws are you referring to? Any screws going into metal should have loctite.
thats good to know . my cen colossus did not and i had to locktite them all myself . figure i ask before it gets here .The three I did - but only cause I disassembled them - were the motor pinion grub, and the grubs on the pinion shaft cups for the differentials... I'm not sure if there are any more, if there are I will add locktite if I take them apart, although thus far any I've taken off already had liberally amount of locktite from the factory on them.
