- Rhode island
- BigRock 4x4
- Kraton 6s
- Outcast 6s
- Vendetta
- Infraction 4x4
there is no cutting, for my system I drilled holes on the roof top for the light brackets and a small hole behind it for the negative and positive wires.same thing for the front and rear lights .Now if you have a light system that has rear ,and front light buckets you would need to cut a opening for them .I'd drill four holes and cut from one hole to the next .making sure you cut out a smaller hole than what the buckets are.,then silicone them in from the back side when you get the fitment you're happy with.What's the trick for cutting the body to install the polo creations light kit?
