Yes you could, but if it’s in a heavy rig like a 1/5 Kraton 8s or DBXL-E you’ll really need to keep an eye on your temps as it will get hotter under load than the Max 5.My Max 5 just took a poop gen 1. I have the Gen 1 Max 6. Will that run an 800 KV motor on 8s? I know it'll work but I just want to know the pros and cons of running it prolong until I can replace it the max 5 that is. Please let me know. Thank you
Too much motor for that ESC. It will probably not last long. What happened to your Max 5? I've had a Max 5 in one of my big rigs for like 4 plus years. I've abused the crap out of it. It even survived a battery going up in smoke. But I have QS8 connectors, I always check for right connections on the bullets and connectors before every run. Get another Max 5. Gen 1 if you can find itMy Max 5 just took a poop gen 1. I have the Gen 1 Max 6. Will that run an 800 KV motor on 8s? I know it'll work but I just want to know the pros and cons of running it prolong until I can replace it the max 5 that is. Please let me know. Thank you
