TheDetroiter
My son’s center diff keeps exploding. I haven’t had an issue with it for about 10 runs, then it blew a hole through the side and basically exploded. I put a brand new one in and it lasted about 10 min and did the exact same thing. I read in one of the forums to run heavier weight in the center diff. I bought another center diff, cleaned out the stock 100k and put 200k in it and also cleaned the front and rear diff (no damage to them) and put higher viscosity oil-I now have 50/200/30. We went out and it lasted about 25 min and started making a weird grinding noise and leaking diff oil. My son is losing interest in the hobby because these cars are constantly breaking. I never had an issue before and my daughter has the exact Kraton and nothing has happened to hers. I also have an Arrma kraton exb and have had no diff issues. All the cars have the same amount of run time because make this a family thing (minus the wife). I starting thinking that maybe the front or rear drive shaft bearing (see attached photos) that goes into the gear box set might be bad and causing resistance which in turn is causing the center diff to overwork. Is this a possibility or is there something else simple that I’m missing. This is getting very expensive and time consuming. Thank you
