Lipo 6s per Typhon 6s.. dubbi
laguna182
good morning everyone..I want to try to configure my typphon in 6s for some speed run tests but I find some inconsistencies on the size of the battery tray..many posts state that the MAXIMUM SIZE MUST NOT EXCEED 158 mm L x 48 mm (width) x51 in height....but on other posts they recommend (with original tray) batteries that have these dimensions 28X45X160mm in 2x3s configuration... on the upper length everything is ok, it only protrudes a little further behind but in terms of height we categorically recommend not to exceed 51!!..what I don't understand?
I use a single Spektrum 6S 5000mah/50C, 142 x 56 x 46mm and it fits fine, I could see another 18mm of length being alright
ok so a single 6s (55x45x160mm) and also 2x3s(28x45x160mm) is ok..right?
I can't confirm from my own experience, but the single sounds like it would fit despite the 18mm extra length of the Spektrum I run, and the two 3S seem likely with a combined height of 56mm
