5mall5nail5
Hey all - been bashing my Mojave with great success for quite a while. A bit ago, I was bashing, and then hear a bad "grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr" and saw some bits hit the road. I think what happened was the e-clip fell off the pinion gear and or the grub screw backed out, as the pinion came right off in hand, but first it destroyed all the teeth on the stock spur gear.
So, I went and ordered a new 16T pinion gear (ARRMA ARA310963) and e-clip along with a Hot Racing Steel Mod 1 Spur Gear ARRMA 1/8 AON50T. I went and swapped the spur and pinion on, but forgot to tighten then grub screw (sigh) in the pinion and it chomped like 3 - 4 teeth off of the spur gear. SO, I ordered a NEW spur gear along with the Hot Racing aluminum center diff housing stuff because the plastic side was stripped out from installing/removing so many times.
I've got it all installed, the pinion is installed with the grub screw loctite'd and tightened, the e-clip is on, the sleeve is on the shaft, etc. Everything sounds great at like 10% throttle with the wheels off the ground, but as soon as I go like 50% throttle it makes a nasty grinding noise. I broke it all down again and even removed the pinion gear to check the shaft on the motor - it seems straight. I powered the motor with the pinion off and it doesn't wobble or anything. I don't know what is up at this point. Should I order the stock spur gear instead? Everything is labeled "Mod 1" but something just sounds off under high load and I am sure it'll chew up teeth if I put it on the ground and hoon.
Can anyone recommend any next steps? Thanks!
