Ugly Betty
- Infraction
- Limitless
super kool,how you manage the extension on the arms to separate the wheels from the body?View attachment 121338View attachment 121339
YES! Very nice! This is mine. It's so much damn fun very nice build man.
What parts did you need to do this conversion?View attachment 121338View attachment 121339
Kraton arms, kraton hubs, 23mm hex extenders from eBay, had to figure out my own way of mounting the body. I built it from the ground up. If you are converting an actual infraction then you are going to need more stuff like shocks and towers and turnbuckles and all that. It might not be worth actually converting an infraction to itWhat parts did you need to do this conversion?
Thanks for the reply. I have a Max6 combo in my infraction. It's already quite beaten up so I thought, why not convert it into an MT & bash it till the limitsKraton arms, kraton hubs, 23mm hex extenders from eBay, had to figure out my own way of mounting the body. I built it from the ground up. If you are converting an actual infraction then you are going to need more stuff like shocks and towers and turnbuckles and all that. It might not be worth actually converting an infraction to it
Well go for it!! You will probably like it. Honestly though you might as well just buy a mojave chassis and slap everything on thatThanks for the reply. I have a Max6 combo in my infraction. It's already quite beaten up so I thought, why not convert it into an MT & bash it till the limits
Look like you have little steering?View attachment 121338View attachment 121339
Actually I was able to full steer. But that was running kraton hubs and 30mm hex extenders to get those tires far enough outLook like you have little steering?
What tires can you run and have full steering?
What u need to make the tires look more outView attachment 121338View attachment 121339
You can get hex extenders from different companies or eBay onesWhat u need to make the tires look more out
