HELP. How do you install the pivot ball that popped out? Just force it in?
TMINOR
Jacksonville Florida
ive already backed out opposite screw but pivot ball has a rounded end that needs to push through...any suggestion on getting it back whee It belongs...
Your second picture is on the right track... After you remove the red cap, there is a black plastic cup-washer thing that needs to be removed. Then the pillow ball threaded end will slide thru. Screw the PB into the a-arm, put the plastic washer back in the hole, screw down the red cap (not too tight, make sure the pillow ball moves free) and you are done.
Jerry-rigged. Thanks. I see what your saying. I was under the impression that the black plastic cup washer thing could not be removed. I'll just try to push it out with a screw driver? I couldn't get the pillow ball to thread through it because the ball is rounded before the screw. I'll try to take that "cup washer thing" out when I get home. MUCH appreciated bro!
