joshjosh
Fast, Faster, Boom…
Military Veteran
- Thread starter
- #41
There’s been quite the pause on this build. Turns out the Vitavon 6S shafts do not work properly with the factory Arrma 29mm EXB diff cups. The Vitavon shaft is 1mm longer than stock, and that combined with having a rounded shaft end keeps it from being able to seat properly, and pushes the hub out where the tire had positive camber. I fought with Vitavon for 2 weeks on the issue. After they refused to do anything I finally just gave up and ordered the Vitavon EXB diff cups to be done with it, then waited 2 more weeks for those to come in.she’s going 8S boys! Swapping out the 4985 for a 4990!View attachment 354311
Rounded end on the Vitavon shaft (right)
Vitavon shaft in Arrma EXB cup
Vitavon shaft in a Vitavon cup
