- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
Hi Drone FPV guys.
Could you enlighten me on what a simple low cost setup might be that can handle ground 2000 ft range for FPV. It appears you have the TX and RX for the car and then also need a camera which has a trasmitter on it and the radio/screen has an RX to recieve that signal from the camera? Is that how it works?
The new RadioLink RC8x has the option to run the Crossfire long-range module which I would like to run, but also they also show a module plugged in instead to the same port that is for FPV use and the screen of the radio can show the FPV. Is it safe to assume I could not run both?
The radio can be paired paried with several RX units but the best one seems to be the R8F 2-way
Looks like this could get expensive!
$300 radio
$200 TBS Crossfire
$ ? - Camera
$ ? - FPV RX module
$300 radio
$200 TBS Crossfire
$ ? - Camera
$ ? - FPV RX module
