Fireteam Cv driveshaft
Anthony jaques
Delta colorado
  1. Fireteam
  2. Vendetta
Do any of yall know of stronger cv axles for these 6s models I havnt had an issue with stock but in my searching I've only found gpm which we all know is sub par and vitavon but that 130 for axles holy cow anyway just research knowledge is power
M2C? The weak spot will be the 2.5mm cross pin.
CVD cross pins are the drive part I break the most. Hub cross pins are #2 on the list. If I replace them every 4-5 months I don't have a problem. It's the price I pay for running a Hobbywing Porky for a motor.
This is good to know, do you know if you can swap these over in the rear to effectively upgrade to a CVD?
As long as you have the widened hubs they’re symmetrical front and rear.
