- Northern VA
- Fireteam
- Infraction
- Limitless
- Kraton EXB
- Mojave EXB
- Outcast EXB
- Talion EXB
- Typhon TLR
I was searching and researching for awhile and couldn't find a solid answer to this:
"Is there a CVD driveshaft or axle with the holes that line up with the offset of the rear hex?"
For those of you in the know, the rear 17mm hex has an offset to widen out the rear track and doing so require a different rear axle with the hole closer to the outer edge vs. the front axle that's closer to the inner hub. Is there a particular part that's available where I can continue to maintain this rear track width without switching to the front axle and using the front CVDs?
