I recently installed a Castle Creations 1717 (1650KV) motor with a Mamba Monster X 8s ESC. My questions are:
For context- I’m running a Tekno 20t pinion and the factory spur gear that comes on the Kraton 6s EXB.
I understand the heatsink and fans might be overkill since I’m not running a really large (relatively speaking) pinion.
Any direction would be much appreciated.
**UPDATED September 25th, 2020**
So the setup I ended up going with was an Arrma Kraton 8s motor heatsink (ARA390296), @suchtragedy was kind enough to lend me a helping hand by 3d printing me one of his designs, the Kraton 8s dual 30mm fan motor heatsink adapter plate, which can be found here: https://www.thingiverse.com/thing:4460604
I decided to pair it with two ProTek RC 30x30x10mm aluminum high speed high voltage cooling fans (PTK-2111). With those fans I did need to extend the cable length with two cable extenders from Ruddog. One 150mm receiver extension wire w/JR plug (RDGRP-0208) and one 200mm receiver extension wire w/JR plug (RDGRP-0209).
The only reason I went with those extensions is because I couldn't find any two wire 200mm extensions in black.
So far I've been very happy with the setup, I ran the car through a full 5000mah 100c pack at 7.4v and I had zero overheating issues. For the record, I run a Tekno 23t pinion gear and I have my Castle to shutoff at 180 degrees Fahrenheit. I can't thank @suchtragedy for not only coming up with a great design to run the dual fan setup, but also helping me with the printing component.
Lastly, I got 8 stainless steel screws from Ace Hardware to get everything snugged into place. Thanks again for everyones help!
- Do you know of any heatsinks that fit this motor?
- Do you know of any fans that would fit on your recommended heatsinks?
